SERIOUS OPINIONS/INPUT NEEDED: big swap idea
RE: SERIOUS OPINIONS/INPUT NEEDED: big swap idea
what type of power were you looking at with a GT30R? and depending on that, that's where you need to find out what fuel management system you'll use. and yes, you're missing A LOT of parts.
ORIGINAL: ej6buddy
if you're getting someone else to do all the work, you might as well buy a new car considering you'll probably have to double the cost of all the parts.
ORIGINAL: ej6buddy
I read around online that with the GT30R + Turbonetics Turbo + the B18C engine you could tune it up to run around 325-350 at 13psi. For my purposes, I don't think I'll be running that strong. Thankfully with the job I have, finding money isn't much of a problem once the winter/spring comes around (just got a high-paying job 2 weeks ago, and around winter/spring is when I think I'd be doing the conversion, if I go ahead with it).
The B18C Type-R motor package comes with the LSD Hydraulic Transmission, ECU, Axles, Shift Linkage, Stock Motor Mounts, Alternator, Starter, Clutch, Flywheel, Intake Manifold, Exhaust Manifold, Fuel Rail, Injectors, Distributor, Engine Harness, and Sensors. The T3/T04B Turbonetics Turbo package comes with theCast-Steel Turbo Manifold, Mandrel-Bent Downpipe, Turbonetics Evolution 35mm Wastegate, Spearco W.A.V.E. Front-Mount Intercooler, Silver Metallic Intercooler Piping, MF2 ERL 3D Map Injector Controller, MSD Boost Timing Manager, 440cc Lucas Fuel Injectors, Turbonetics Raptor Blow Off Valve, 2 Bar Map Sensor, K&N Air Filter, Synthetic Turbo Oil, Hardware&Fittings, and the GT30R Dual Ball Bearings. So in terms of the manual conversion, besides what's listed in these packages (like the 5spd Transmission, clutch, etc.), the pedals, a short shifter, and a shifting ****, what else am I missing to complete the process?
Just want to make sure I have it all laid out in front of me to know what I'd be in for.
ORIGINAL: Pete
Drive it another year. Buy a new SI.
you know that you're not going to get back the money you put into the car, so I say sell your current car, and get a brand new civic si, and boost it.
ORIGINAL: theblackpearl
sounds to me like a pretty good set up
now good luck on finding that person to do the swap with
ORIGINAL: Masonn
+5!!!
ORIGINAL: Pete
i could wait a year or so and then do that. tempting... tempting... it's so hard to let go of your 6 year companion though.
EG SWAP INFO NEEDED, I NEED EVERYONES INPUT SO THAT I CAN MAKE A STICKY ON THE GROCERY LIST!!!!!!!!!
MarcB
EG Swaps
12
05-02-2007 01:20 AM
