Shifting into neutral at every stop ?
RE: Shifting into neutral at every stop ?
Stay in gear while rolling to a stop. While you are not touching the gas pedal and the inertia of the car is spinning the engine faster than idle speed, the ECU will turn the fuel injectors completely off.
The only time to roll to a stop in neutral is if you are a long way off and are not going to make it there without using some gas if you had stayed in gear. Note that being in neutral while the vehicle is moving is illegal in most states.
If you're stopped and not gong to need the engine for a minute or more, turn it off completely and then restart it. You may end up spending your gas savings on a new starter though. It is highly dangerous (and of course also illegal) to have the car moving with the engine off. The power steering, power brakes, ABS, and air bags are all going to be disabled.
ORIGINAL: b_rice burner
ya dropping into neutral is the best way to keep clucth fresh and save on gas just remember if you are coming to a stop and drop to neutral then it goes green always drop to a higher gear then drop down to save on wear and tear so ex: if you car is in speed for 2nd always drop to 3rd then drop to second after to save on the grinding factor, but yes goin to neutral will save in gas by far....
BoughtAbrokeHonda
10-12-2014 05:54 PM
egvtec14
12-03-2009 02:35 AM
