Specific parts / what they do?
If you can help me that'd be great..I just need a small description on what it does, purposes of it, and if it increases performance any? (if applicable)
Timing Belt
Water Pump
Dist Cap
OEM Wires and Plugs
Headgasket (rebuilt by a Honda Tech)
Spoon ECU
AEM Hybrid Cold Air Intake
Greddy Cat Back Exhaust
Cusco Front upper strut bar
Cusco Front lower tie bar
EM's Racing rear upper strut bar
EM's Racing C pillar bar
EM's Racing triangle bar
Nuespeed rear lower tie bar
Cusco 6 point rollcage with chrome Cusco 7th bar
Hasport motor mounts
Hasport shift linkage
Hasport wiring harness
Exedy Street Clutch
Battery relocation? (rear end)
I'm just here to learn as much about my 'passed' down car as much as possible! Thank you very much.
Timing Belt
Water Pump
Dist Cap
OEM Wires and Plugs
Spoon ECU
Exedy Street Clutch
RE: Specific parts / what they do?
this:
this:
and this:
Exedy Street Clutch
this:
and this:
Exedy Street Clutch
I found out strut bars help out in suspension and handling corners but what do full rollcages like the one stated above do?
That clutch was brand new installed so I guess I know the benefits of that.
What exactly do the Hasport products do? (motor mounts, shift linkage, wiring harness)
For the greddy catback exhaust..I'm almost 100% sure that it's the SP2.
Benefits of an AEM cold air intake (HYBRID)? It's always cold here in the bay area! yeaah
and finally was just wondering about what do these do: (performance/handling/other gains)
Timing Belt
Water Pump
Dist Cap
OEM Wires and Plugs
Spoon ECU (not sure how it's programmed)
Battery relocation to the rear trunk
Thanks a lot everybody!
Timing Belt
Water Pump
Dist Cap
OEM Wires and Plugs
These are all necessary for your car to run properly. The come stock:
Timing Belt
Water Pump
Dist Cap
OEM Wires and Plugs
Headgasket
The ECU, Intake, and Exhaust all help performance (horsepower/tq wise).
These are all suspension upgrades that help the handling (taking corners quickly, etc.):
I'm pretty sure the Hasport stuff is for an engine swap.
The battery relocation just frees up room under the hood.
And obviously, the rollcage will keep the car from crushing on top of you if you flip your car.
Timing Belt
Water Pump
Dist Cap
OEM Wires and Plugs
Headgasket
headers look into DC Sports, Apexi, etc. i would go with DC Sports b/c they have like just about every imaginable header(almost). but i dunno how much power u will get out of it. They say 10 HP but i seriously doubt it.
-B
-B
