SPEEDO PROBLEM
Old 03-07-2007, 03:24 PM
JDMOBEY's Avatar
Default SPEEDO PROBLEM
got a speedo problem. When I turn on the car, its pinned at 20 mph. For the week that i've owned it, i've only seen it work twice - then back to 20 mph. I figured it could either be a bad cluster or the vss. I tried an auto vss into my manual tranny, weird, didnt think it would work becuase the auto vss is smaller then manual vss. Tried it anyway, turned on the car, just turned the key right before ignition - needle dropped down to 15 mph. I put back all parts into the rights cars, forgot to plug the socket into the vss in my car, turned the car on, still pinned at 20 mph, I then realized it wasnt pluged in, still pinned at 20 mph. I even scanned the obd, "0" errors/faults. Could this be a bad cluster? and should i even buy a new vss just to be sure?
Old 03-07-2007, 03:33 PM
Red Hot Rider's Avatar
Default RE: SPEEDO PROBLEM
What year is car? Sounds like the speedo is bad and needs to be swapped out.
Old 03-07-2007, 03:39 PM
JDMOBEY's Avatar
its a 98 coupe EX, manual. I think so too, but i want to be sure whatvever i fix is the right one
Old 03-07-2007, 04:14 PM
Wait for more experienced to chime in, as I'm still new. But that's what it sounds like. Very easy to replace. Two screws for the bezel, four screws for the cluster, pop the plastic pieces off carefully watching the one light with the wire, four screws hold in the speedo. Install is simply the reverse.
Old 03-07-2007, 05:12 PM
JDMOBEY's Avatar
thanks for the input! yea, i'll wait also for the others in reply too
liljohnny
09-25-2007 11:10 AM
Forty04
09-17-2007 04:28 PM
chadmcd
11-13-2006 03:12 PM
koots
08-22-2006 01:52 AM
nigel_miguel
07-06-2005 09:38 PM
Quick Reply: SPEEDO PROBLEM
