speedometer issues
Old 03-12-2009, 04:39 AM
.:civicdriver:.'s Avatar
Default speedometer issues
i have just gotten my honda civic in december and my speedometer is just compley messed and it realely works and it also says im going 80 when i havent even started moving... what could be the problem?
Old 03-12-2009, 04:56 AM
danomatic93's Avatar
June 2010 ROTM
It would help to know what year she is...
If CEL is on, check the CEL FIRST!!
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
Old 03-12-2009, 09:16 AM
its a 1995 civic cx
Old 03-12-2009, 10:05 AM
June 2010 ROTM
More than likely your speedo gauge in the cluster is shot. But, follow the steps above to be sure. CEL = Check engine light
spenny
05-23-2009 07:42 AM
gas_miser
12
03-13-2009 08:01 AM
Its Me
06-20-2008 07:19 AM
ctyree1243
01-21-2007 02:42 AM
AnakinKenobe
08-19-2004 05:44 AM
Quick Reply: speedometer issues
