Speedometer Trouble
Old 02-25-2010, 06:53 PM
Originally Posted by m@nny
I have the same problem on my '00 EX, at autozone they told me it was the speed sensor, but i also hope its not the cluster like you said Punisher.
Is the CEL on? Any CEL codes?
Old 02-25-2010, 07:21 PM
m@nny's Avatar
pardon my ignorance but what's CEL? >.<
if you're talking about the check engine light, it's on, they said it was the oxygen sensor...
Old 02-25-2010, 07:22 PM
Never ignore a CEL. Click the CEL link in my signature to learn how to pull the codes with a jumper wire at home. Post the codes you retrieve.
Old 02-25-2010, 07:39 PM
m@nny's Avatar
ok will do that tomorrow cause its dark and cold outside >.< thx!
Old 06-28-2010, 07:37 PM
gishar's Avatar
I have the same problem with the speedometer! it works most of the time but sometimes it lays on zero!! and no clue for when it happens! odometer works okay but speedo's being a headache! I need to know what's my speed. any idea on this? I appreciate your help guys. Thanks
Old 06-29-2010, 11:05 AM
Odometer working but speedometer not means the problem is in the speedometer head in the cluster. You could try taking the unit out of the cluster and resolder all the connections on its circuit board like you would a main relay. Also check that the speedometer pointer is not dragging on the dial face.
CatsnotCars
01-28-2015 12:24 PM
ahhsimon
05-08-2005 10:07 PM
billybaroo
03-02-2005 11:33 PM
dayquon
09-01-2004 02:45 PM
AnakinKenobe
08-19-2004 05:44 AM
Quick Reply: Speedometer Trouble
