Stiiiick Shift
Old 01-07-2007, 01:08 PM
Jeremy102579's Avatar
Default RE: Stiiiick Shift
i dont know, i only push the clutch in as far as i have to to shift, why push it in all the way if you dont have to?
Old 01-07-2007, 01:15 PM
Misha's Avatar
I really mean it's a good point. As long as your not grinding, I think you are fine...
Old 01-07-2007, 03:22 PM
mill$civic's Avatar
If you look in the honda manual it tells you to push the clutch in all the way to prevent premature wear.
Old 01-07-2007, 06:00 PM
Misha's Avatar
Mill, this is definitely what you don't recommend to an unskilled "shifter", but when person is experienced enough to be able to tell where clutch is fully disengaged and is lazy enough not to push it all the way down, I don't really see a problem...
Old 01-07-2007, 06:21 PM
Mr Mobsta Man's Avatar
theres no since in risking it. don't be lazy
Old 01-07-2007, 07:31 PM
Inev's Avatar
Well I think I got it a little bit,
I started to let the clutch out a little and when it started to give a little, I gave it some gas, and smooth sailing.
Needto practice a little bit, but is that how you do your gentle launch?
Old 01-07-2007, 08:01 PM
Misha's Avatar
Yea, sounds pretty good, keep practicing
Old 01-07-2007, 09:10 PM
For everyone that has driven a stick for a while, it is all muscle memory. Once you've driven for a month or so it should be "instinct."
Old 01-07-2007, 09:18 PM
Pete's Avatar
I learned in a week, if it takes you longer than that........................well then I guess you suck at life.
Old 01-07-2007, 09:22 PM
It took you a week!? 168 hours to learn how to drive a stick. Pete you are a slacker if it took you that long.
Quick Reply: Stiiiick Shift
