striped oil pan threads
Old 04-09-2007, 08:54 PM
97_ex's Avatar
Default striped oil pan threads
looks like the jackasses at jiffy-lube stripedthe threads onmy oil pan when i went to kansas for a visit... just noticed it tonight when i went to change my oil. what can be done with out changing the oil pan out? i found one at autozone for alittle less than $100, where can i get a new one cheaper?
Old 04-09-2007, 08:57 PM
Default RE: striped oil pan threads
Are they stripped real bad? Tap and dye set would solve the problem.
Old 04-09-2007, 09:00 PM
97_ex's Avatar
it just keeps turning and turning.... it will start to get tight and then go loose real fast! i thought something was up when i took the plug off and there was a piece of metal that looked like a spring right at the edge... i've never used a tap and dye... how does it work? would i have to get a larger plug?
Old 04-09-2007, 09:06 PM
ebay........ would be your cheapest bet...
but if ya need the bolt in thier ASAP and your GONNA SWAP out the pan... just get some epoxy, mix it up and push some of it into the bolt hole threads then more on the bolt and just snug the bolt the best ya can and wait until the epoxy is dry before puting any oil in it..... should be fine till ya replace the oil pan.... but it will be trashed then.
Old 04-09-2007, 09:08 PM
We just used one today to straighten out some jacked up threads. Now I'm not sure if this will work for you.
Old 04-09-2007, 09:14 PM
mill$civic's Avatar
It doesnt look that hard to swap out. Only like 10 bolts or somthing.
I would be sooooooooo pissed if I was you. A $20 oil change with a $100 mistake.[:@]
Old 04-09-2007, 09:17 PM
97_ex's Avatar
yeah... wish i could do something about it, but i don't know where it was! i just know i was somewhere in kansas city! this sucks!
ORIGINAL: mill$civic
Old 04-09-2007, 09:36 PM
ya thats why i always do my own work....LOL most those quickie lube places hire these kids..... hell i knew a few of them in school that worked at the walmart car center..... and one of them got fired for not puting the drain plug back in! and the owner drove off and engine locked up shortly down the road.LOL
i messed up my impalas old oil pan a few times.... but its american steel..... and i just welded anew bung on it....
Old 04-09-2007, 11:09 PM
97_ex's Avatar
what if i put epoxy on the outside of the pan around the bolt? it would hold good enough right?
Old 04-09-2007, 11:16 PM
danomatic93's Avatar
June 2010 ROTM
for temporary, yeah
Quick Reply: striped oil pan threads
