striped oil pan threads
RE: striped oil pan threads
In the manual
It's really not all that hard to do. Just irritating because there isn't one combination of tools that works. One nut will require a small rachet and deepwell, the next will need a regular socket and an extension, next will be a big rachet, etc.. Straight forward, but annoying
dito.... tho put the epoxy on the inside threads as well... other wise only the outter layer will hold the bolt inplace if its striped to bad..... ya need alittle inside bite for a beter ghetto quick fix.....
but for the replacement... not sure if the pans made outta pot metal or aluminum.... but if aluminium... you could always try taking it to a welding shop and asking how much they would charge to weld a new bung on the pan....
but most likely it would still be cheaper to buy a used one and hope those threads arent jacked up as well...
i never use a torque wrench on my oil plug... i always just judge it myself and be aware how large your wrench is.LOL
also new crush rings every few oil changes as well...
i got this stuff called quick steel, mixes like puttyand it says it hardens as hard if not harder than steel. it is good upto 500 degrees. no way my pan will heat up to 500 degrees... right??
ORIGINAL: Forty04
In the manual
In the manual
and you need to drop the exhaust manifold to do it.
D16Y8 oil pan is aluminum.
ya that stuff should work preaty good... but just like the epoxy put alittle on the inside threads......
and with that stuff.... best ya use some gloves when rollen that stuff around mixing it realy good! you want a good even grey color! i used that stuff on the steam tables at my work to plug some holes and it worked great until some newbie was cleaning the steam tables and dug that stuff out with a knife! NEWBIES......LOL
reminds me i gotta buy some more of that to fix them tables.LMFAO
JUST MIX IT REALY GOOD BEFORE APPLYING!
first time i used that stuff i didnt know the center was black and had to be mixed realy good.LOL it still held together my heater hose on my old 66impala tho... LMFAO heater hose split and i used that stuff and some duct tape to hold it together for a week before i had time to get a new hose.LOL
