Which Struts???
Old 05-28-2009, 05:34 PM
VONSTER's Avatar
Default Which Struts???
What is the best struts to replace my stock ones with on my 98 Civic? I do not wish to lower it or anything else I just want to beef up the ride a little and of course I dont want to spend a fortune either. When I do this is there any other things that should be changed while Im underneath there?
Thanks
Old 05-29-2009, 01:19 AM
I would consider doing a very mild drop. H&R OE Sport springs will give you a .25" drop or something like that. Might be worth looking into. Gives you a slightly more aggressive stance, better springs, without being too low at all.
It all depends what you want as far as shocks go. If you're not going to lower (or are only going to lower a tiny bit like the springs I mentioned), I would just buy KYB GR-2 shocks/struts.
KYB AGX would be nicer to have though, due to the adjustability of the dampening force, that way you can decide for sure how you want them after you get them. You can set them from really soft all the way to really stiff with the push (important that you push) and twist of a screwdriver at the top of the shock piston (fronts) and the twist of a **** (**** is on rears). I love mine.
Old 05-30-2009, 07:00 PM
99ek9's Avatar
Go with Tanabe because there cheap and effective, or Teins.
Old 05-31-2009, 12:50 AM
Beretta's Avatar
For better handling and staying similar to stock I agree with the KYB GR-2's. Plus, you can pick those up for a good price.
Old 05-31-2009, 05:31 AM
inthezoneac's Avatar
what do you mean important that you push?
probably the cheapest you'll find them new is on ebay
agx set $400
gr2 set $235
Old 05-31-2009, 08:20 AM
jwmm04's Avatar
August 2010 ROTM
There is a little **** on top of the front shocks, with settings of 1-4 on it. It is possible to just turn this **** to a number, without pushing it down first. If you didn't push it down all the way in before you select a new setting, it won't select it right.
I put the KYB AGX's on my car a month or so ago. Man, the ride is great; I sure love these struts!
Old 05-31-2009, 08:39 AM
nvm I thought u were talking about something else
Old 05-31-2009, 01:01 PM
yea, that. you also have a chance of snapping the **** if you don't push it down
Evoman
05-18-2009 07:02 AM
branx
03-24-2008 04:32 PM
nate081304
01-16-2007 07:41 PM
ic892003
17
11-24-2006 10:30 PM
baddriver86
09-16-2005 11:49 AM
Quick Reply: Which Struts???
