TB Tranny clutch?
TB Tranny clutch?
When I push in the clutch i hear a whistling sound. What is this? I don't remember ever hearing it. I cant hear it when i and shifting through the gears because of engine noise but when I'm at a stop and I push the clutch in to go in first i hear this whirling whistling sound. Problem??
thanks
Brandon
thanks
Brandon
sounds like ur throwout bearin. i got the same problem only i hear mine when i dont press the clutch. u need to change the TOB and grease it up. if your clutch is old might as well change it since the tranny has to be takin out. Kit comes with a TOB anyway
if you hear yours when you don't press the clutch and it goes away when you do press the clutch, you've got a shot input shaft bearing. TO bearing makes noise when you push the clutch in, if it's bad.
VXHatchHero
06-13-2010 09:42 AM
NIKE H34D
01-05-2009 01:04 PM
addiction2bass
04-13-2008 05:19 PM
jtvision
01-11-2007 07:58 AM
HARI.
10-08-2006 09:46 PM
