is there such thing?
Old 06-03-2010, 01:25 PM
...NEED4SPEED...'s Avatar
Default is there such thing?
hey peoples... this might be a dumb question but, is there such thing as heat soak? if yes, wat is it and wat does it do?
Old 06-03-2010, 01:27 PM
I've heard of a heat SINK.
Old 06-03-2010, 01:36 PM
i'm askin cause dis guy said i had heat soak.... i said, ok? never heard of it...
Old 06-04-2010, 09:03 AM
so thats what he meant it as? a useles pos? this is wat i told him...
"My motor sometimes feels this real small lack of power. its great at one point, then when i turn it off and come back in 5 min and drive again it feels different. its a similar change in feeling to when i turn my A/C on then off."
then he said,
"Maybe you have a hot soak situation that is allowing the fuel to boil in the rail, but that would clear up fairly fast. Maybe a coolant temperature sensor or air temperature sensor is causing it to revert to cold start mode for a while."
Old 06-04-2010, 09:14 AM
Fuel boiling in the lines under the hood is more properly called vapor lock. Like most fuel injected cars, it really can't happen on a 95 Civic since the fuel is forced to recirculate back to the tank (which remains relatively cool) all the time.
Old 06-04-2010, 09:59 AM
GhostSi's Avatar
+1 ^^
Old 06-04-2010, 04:15 PM
so its normal then?
Old 06-04-2010, 04:44 PM
Originally Posted by ...NEED4SPEED...
so its normal then?
mk378 just said that it wasn't what is happening because it's not possible the way your fuel system is designed. It can't be what your problem is.
reading comprehension bro... work on it
Old 06-04-2010, 06:01 PM
sorry trust, lol... i'm just havin a ruff day. my has one month left till the baby comes. i'm gonna do a tune up soon and see wat happens. wat spark plugs u recommend. ngk?
Quick Reply: is there such thing?
