True HElp needed!
Old 04-19-2012, 07:26 AM
ChristianL's Avatar
But that's not a "tie rod". Yes, it's a brace that'll tie together two points on the subframe, but it's not one of the "tie rods" that help you steer the front of the car. If the car had four-wheel steering, then yes, he'd have rear tie rods.
The OP already replaced his tie rods, and I didn't want him to get confused.
Old 04-19-2012, 07:59 AM
GreenToy's Avatar
Ah, okay. I used the wrong terminology. My bad.
Old 04-19-2012, 08:57 AM
ChristianL's Avatar
No prob - and I made the assumption you meant lower control arms, so I'm a bit to blame, too.
Old 04-19-2012, 09:56 AM
ImARyDer's Avatar
Ok..now i am understanding a lot better. SO I need to replace my coilovers i have now for either some stiffness shocks? or probably get some heavy duty lowering springs and keep my stock shocks? I have just the coilover set up RiGHt(now).. Could i get 3-5 listings of setups i should get for a nice cornering, ground zero balance while going across railroad tracks, or sewer plates!!!
Old 04-19-2012, 10:09 AM
ChristianL's Avatar
Stock shocks are really only good for stock spring rates. If you're currently using stiffer springs, you'll need to upgrade your shocks to help control them.
Imagine jumping on a mattress, then you stop. You won't stop instantly - you'll still bounce a couple of times before coming to a complete stop, right? That's basically what's happening with your car. Every time it hits a bump, it'll bounce on the springs, and keep bouncing until it loses kinetic energy, or there's something to help dampen the bounce (which should be your shocks).
Since the stock shocks are designed for softer springs, they're not strong enough to control the stiffer springs you have now.
Get some decent shocks (KYB - not the GR2, Koni, Tokico - but not the HP), and I'll bet the car will ride like a champ. You may not even need sway bars if you set it up correctly.
Do you know what the spring rates are for the new ones you just bought?
Old 06-20-2012, 11:02 PM
ImARyDer's Avatar
Currently on now are some off brand coilovers.. So can i upgrade shocks on there or is all that eliminated? Should i replace back to the stock springs and shocks, then add lowering springs on then top that with some good shocks?
Old 06-20-2012, 11:09 PM
ImARyDer's Avatar
Also.. Sometimes once i go to look up parts they dont have the area for me to select the swap i have. so could i go wit the ex 1.6 instead of the 93 1.5L listing?
Old 06-21-2012, 04:26 AM
Treat the car like it's a Civic LX. It likely still has the LX brakes versus the slightly large EX brakes, and things like that.
Old 03-14-2013, 05:22 PM
ImARyDer's Avatar
Thanks for the help! After I searched the vin it is a LX just with the d16z6.
Jippo99
03-26-2005 07:03 PM
dalifts
12-05-2004 05:13 PM
D16z6
08-19-2004 06:44 PM
baker7598
06-10-2004 09:33 AM
Quick Reply: True HElp needed!
