Trunk Leak
Old 05-10-2009, 09:25 AM
DNkG's Avatar
Default Trunk Leak
Hi,
Recently i thaught i fixed the trunk leak by putting in a missing plastic grommet. But it still leaks and i think its due to the sunroof drain on the left side of the trunk. The tube seems kinda slow draining when i pour water down there. How specifically can i clean this drain tube the whole way? i think it mainly must be the bottom part where it joins in the trunk, can i just pour draino down there LOL seriously? thANKS
Old 05-10-2009, 03:01 PM
stoochy's Avatar
You could blow it out with compressed air, would be the easiest. Or use a long piece of wire.
Old 05-11-2009, 01:36 PM
DNkG's Avatar
Use an air chuck? i tried using a clotheshanger but it only got stuck at the beggining. It seems like if i blow all the buildup down it will get stuck at the weird exit by the rear bumper. Is it usually only the bottom peice that gets clogged up? Thanks
Old 05-11-2009, 02:15 PM
ya it usually cloggs at the bottom because the dirt dries up there and just keeps clogging up more and more. i just used compressed air from my home air compressor... put alittle soapy water down the drain holes and blew it thru again.
Old 05-11-2009, 02:19 PM
Superfly's Avatar
you have a 99 civic right?
J/w did you look at my pic? https://www.hondacivicforum.com/foru...ad.php?t=75166
Old 05-12-2009, 05:46 AM
Robzilla's Avatar
It seems like you found your source but one other thing to check with a trunk leak is the bolts that hold the trunk lid on. I have seen them get loose before and it let water in the trunk. Subs usually cause the problem.
Old 05-13-2009, 03:31 AM
DNkG's Avatar
Hey superfly i did see your pic, it does seem like the water is comming in from that side. How did you fix your leak?
Old 05-13-2009, 04:28 AM
Superfly's Avatar
Sweet! FYI it's probably coming in on both sides....was for me.....and i haven't fixed it yet
I'd recommend using some JB Weld or clear silicone II or something of that sort
Gmmolina
03-19-2011 10:20 AM
wingzeroac195
03-06-2010 06:54 PM
asadzanjani
02-13-2008 04:37 AM
meanNgreen
12-18-2007 05:12 PM
addiction2bass
06-08-2007 06:02 PM
Quick Reply: Trunk Leak
