Tune up time!
Tune up time!
Yo!
So its time to do another tune up on my whip! Just wanted to get a feel for what are some of the better wires and spark plugs that are out there. I hear that ngk wires and plugs are pretty good. What do you guys think?
Thanks,
Thanks,
RE: Tune up time!
I would just go with OEM honda stuff. you can spend $50-$70 on NGK plug wires or other pro series, but it wont make a real difference if anything at all, unless you got some mods under the hood. NGK makes spark plugs specifically for honda motors so thats a good start. You might want to check the distributor cap and rotor for corrosion (white build up). You can scrape off the stuff with some fine grit sandpaper or just buy a new distributor cap and rotor.
Also check into seafoaming your car if you haven't already. Restores engine performance and is real fun to do
