Type r swap
No problem man. You would get a lot more bang for the buck by building a turbo motor and boosting the hell out of it. But I'm partial to DOHC Vtec, there's nothing quite like it. And if you spend the initial money on the DOHC and then, after you save up more money, build and turbo that, you would be making SO much more power. That's what I would do.
ok im back see told you so hahahahahaha, i have been lookin in to buying all the stuff needed before the motor arives, and the mounts im gonna go with are either hasport, or innovative........ ok now the swap comes with
LSD Manual Transmission
Half shaft
ECU (computer)
Axles
Shift linkage
Motor mounts
Rear mount
so just some questions about this. will the motor mounts that come with it work in my 90 si. if not thats cool i know where im going. two. is this the shift linkage im gonna need or do i need to buy aftermarket again. three will these axles work or once agian do i need to buy aftermarket. just school my noob *** so i can stop tripping hahahahahaha thanks any help would be appreciated
Half shaft
ECU (computer)
Axles
Shift linkage
Motor mounts
Rear mount
im not completely sure but if you gave them the year of your car they should have given you the right ones (provided you paid for them) the shift linkage theyre giving you wont work and the axles should work
also i suggest changing the timing belt and water pump and upgrading your clutch
I am working on that swap right now for my 99 HX. Having some ECU/harness issues. The only thing that I would recommend is getting a good set of motor mounts. I went with the Innovation B series motor mounts from swap shop motors http://www.swapshopracing.com/contents/en-us/d675.html. I tried eBay but that was a nightmare.
right on agian, ok, i went to swapshop actually and saw they had two types of mounts, ones for the hydro and one for the cable. im gonna stick with the hydro, but that **** cost double what the cable mounts cost. it also comes with two extra brackets that i have no clue what to do with, i want to go with a cable to hydro conversion the one from hasport, and im pretty sure those bolt on the cross memeber. so what do i need those other brackets for. or should i just use the mounts that are for the cable. hahahaha sorry if that **** is messed up, just rambling on
ben
ben
Ghetto2315
07-13-2008 03:18 PM
krzemienr
12-07-2006 01:30 PM
blkcivicman05
04-29-2005 10:37 PM
