Vacuum A/C System
Old 05-28-2011, 01:57 PM
D16z6's Avatar
Exclamation Vacuum A/C System
What's the reading suppose to be on the low and high on the manifold gauge when the pump is running? What should it be when its off? I'm getting zero on both side. Is this normal? If there is a leak in the system what would it read? I have a 94 EX with R134 system.
Old 05-29-2011, 05:26 AM
Zero pressure means you have no refrigerant, almost certainly due to a major leak. The compressor should not engage in this condition, as there is a low pressure cutout switch to protect the compressor. Normally with the compressor off (and it has been off for a long time, a so-called "static" situation) both pressures should be around 90 psi, more or less depending on the temperature.
turbotiffiny
08-09-2008 02:02 PM
windcalmer
04-30-2006 03:43 AM
Street Sniper
08-17-2005 12:21 AM
xonic
05-26-2005 04:58 PM
civic9988
10-24-2004 07:22 PM
Quick Reply: Vacuum A/C System
