what is the best way to do a engine swap
Old 04-06-2007, 08:31 AM
blackmetal619's Avatar
Default RE: what is the best way to do a engine swap
ORIGINAL: 01 honda
ya but it a start its got more hp then the engine i have in my car now i got headers for it and i going to put a cold air intake on it and a turbo its the first engine that i bought for my car im going to buy a beter engine later on down the road.
if you turbo it, you wont be using the same header, and you wont be using a cold air intake. So if you plan on going turbo, dont buy a cold air intake
Old 04-06-2007, 08:36 AM
mxs's Avatar
mxs
mxs is offline
ORIGINAL: 01 honda
by the way you can put any engine in any car alls it takes is time and when i put the d16y8 in my 01+civic ill make sure and post the picture.
ok, have fun with that.
Old 04-06-2007, 08:58 AM
riceburner700's Avatar
your best bet is gonna be a k20 it would be easier than puting the d16y8 in
Old 04-06-2007, 09:03 AM
drbyers's Avatar
stop kidding this guy. used k20s are going for roughly for $4,000 - $5,000 alone.
add in the tranny, axles, ecus, aftermarket mounts, installation labor and all that other jazz, and he's already bought another car....
Old 04-06-2007, 11:33 AM
Chimera02EX's Avatar
A 16y8 in an 01+ car will not pass inspection. Putting the engine in can be done, hell anything can be done with enough money. But good luck finding someone who will pass the emissions on that.
Old 04-06-2007, 12:47 PM
4doorcivic9's Avatar
Danomatic93 yes the 01 civics are slow as hell. I raced my friends that has a lot more done to his motor and less miles than mine. I have a 94 4door civic (d16z6) and killed him by 3 cars. There very slow.
But yeah dude, i dont recommend you putting in a y8 either. You'd be better off changing out the ecu or sending it off to hondata and putting an aftermarket IM & TB and putting lots of bolts on (header,CAI, Cam Gear, Underdrive pulleys, exhaust, plugs, msd igition etc.), on your motor, then trying to fork out money on getting that y8 in and passing emissions.
Old 04-06-2007, 03:08 PM
Hondata doesn't chip OBDII, KMS is the only company that makes an aftermarket IM; not even sure if there is an aftermarket TB. Cam gear is pointless without headwork and a stage 2 cam. If you are looking at ignitions make sure they are DIS(distributorless ignition system).
Old 04-06-2007, 03:15 PM
cderalow's Avatar
7th gen D series have pretty much 0 aftermarket support
as to putting a 6th gen motor in a 7th gen car... not going to happen without a buttload of custom fabrication anyway, let alone the emissions
the best bet, is trying to find a k20 of some nature and doing the swap... either from a base rsx, or the 7th gen civic si
Scott53092
09-07-2009 08:38 PM
TIcivic00
06-25-2007 07:05 AM
Auto98EX
09-21-2005 10:11 AM
h8yourv8
08-14-2005 08:44 PM
cool chris
04-21-2005 09:33 PM
Quick Reply: what is the best way to do a engine swap
