what grade oil?
RE: what grade oil?
10w30 will sut you just fine, i use 10w30 royal purple in my beast and it gets down to -10 degrees sometimes and works really well and cleans everything out and better gas milage as well..
RE: what grade oil?
I just put in some 10w30 today. Looks like the teggy needs a head gasket though, there is a small leak coming from inbetween the head and the block. My friend said its a pretty straight forward job. I'lll do some research and see if I'm up to it.
RE: what grade oil?
ORIGINAL: morepower
I have jacks and ramps to lift the car but it's dangerous, i would rather pull it up on a curb and crawl under it, this is the first car that i could not reach the filter without jacking it sucks.
5-20 is very light oil and should change every 5k per manual. I use Dino oil penzoil jiffy lube puts the same 5-20 it all turns black because of the detergent additives. synthetic is better but not worth it unless you change it every 10k and that would look like espresso because of the detergent. Does anybody know of an oil filter relocation mod
RE: what grade oil?
Hey Morepower.
I know Greddy makes an oil filter relocation kit. I think it's around $128.00 and uses a 1985 Toyota Corolla GTS 1.6L oil filter. I've seen a couple civics done this way with a dual filter set-up where the stock battery sits. Dual filter set-ups with magnetic drain plug should keep your oil cleaner than drinking water in some cities[:'(]
Greddy part number for '92-'00 Civic is 12053005.
There are probably other manufacturers that make these but Greddy is Goood.
[IMG]local://upfiles/9113/58C08153848C41F288D9E39150DB1D21.jpg[/IMG]
[IMG]local://upfiles/9113/1FEF26762F35421980CF0B58E7278DBF.jpg[/IMG]
oilltd
06-10-2008 04:06 PM
oilltd
South West
06-10-2008 03:07 PM
