What is seafoam?????
Hey guys,I have seen all these guys talking about seafoam. I was wondering what it does to your car and how you use it. I saw something about it helping your car not burn oil. And on my eclipse it is starting to burn a lil oil after its been running for a little bit. Just wondering if this would help out. Thanks in advance.
Jacob
Jacob
RE: What is seafoam?????
Its a engine cleaner...pretty much gets out all the gunk out of the system..
[ul][*]Cleans fuel injectors[*]Cleans carburetor jets[*]Cleans carbon[*]Stabilizes fuels[*]Upper cylinder lube[*]Removes moisture in fuel[*]De-icerFrees sticky lifters Frees sticky rings Removes moisture in oil Cleans P.C.V. systems Cleans catalytic converter odors Oxygen sensor safe[/ul]all that is taken from there website...its good stuff
https://www.hondacivicforum.com/m_142942/tm.htm
Just get some.. Pour 1/3 into your gas (Having a full tank), 1/3 into your crankcase (its recommended you do it about 100~200 miles before your oil change, because it may water down your oil a little bit), and the other 1/3 into your throttle body(Which is what I did), most people put it in their vacuum pipe, but I found the throttle body more.. I don't know, better in my case. Just pour a little at a time in your throttle body, because it will bog down hard and your engine will shake a bit, you can kill it a few times, thats why you gotta be careful. Just do the rest in there, and maybe rev it a little afterwards and let it idle about 5~10 minutes, and what I did was just drive it up and down the road a little bit, to ensure its in my cars system and everything, then enjoy your new cleaned out car (internally speaking), also.. As a side note, you'll get white smoke depending if your car is really backed up with gunk, all the smoke is, is the gunk burning off into a vapor, so its nothing to worry about, its perfectly normal.
I hope this clears any questions you have about the product. Good luck.
Seafoam is def sweet. It smoothed out my idle alot and i got a little better gas mileage after doing it
It also made me car smoke for like 10-15 min and then the next morning when i started it.
MAD smoke it was sweet heres a vid:
http://s181.photobucket.com/albums/x...nt=Seafoam.flv
ORIGINAL: SuBlime_4_LiFe
I was wondering about this, my car is almost 170k and I don't think it's ever been seafoamed. I've heard about motors being ruined because they were basically held together with all the carbon seals and whatnot. Should I seafoam my engine, or do I run a risk of ruining it because it's pretty old and high up there in miles? My idle seems to be fine, my acceleration seems to be normal, but I don't really have a basis of comparison. I'd love to seafoam, but don't wanna kill my engine.
ORIGINAL: cyberx32
lol did you floor it?
ORIGINAL: cyberx32
lol did you floor it??
stylus
04-07-2006 09:44 AM
