What stock Honda wheels bolt right on to a '94 HB Si?
Old 05-19-2010, 05:10 AM
Rich's Avatar
Default What stock Honda wheels bolt right on to a '94 HB Si?
Do HX wheels bolt right on to a '94 si? What (if any) stock 15" rims would bolt right on? I'm a cheap bastard and was thinking about dolling the old girl up a little. I read a bunch of rim threads but got a little cornfused...
Thank for any tips!
Old 05-19-2010, 07:09 AM
Any 4-bolt honda/acura wheel will bolt up. So yeah, HX wheels will bolt straight up with no problems; we have several members here with HX wheels.
Old 05-19-2010, 08:06 AM
Not all 4 bolt wheels reaper your gonna make him go get accord or prelude rims lol
Old 05-19-2010, 08:09 AM
Pshh... he wants HX wheels anyway.
Seriously, since when do accords/preludes have a different bolt pattern? I did not know that lol.
Old 05-19-2010, 08:26 AM
Dipsetcivic117's Avatar
isnt there a caliper issue with these rims? i could have sworn there was unless if its the ek's with the caliper issue
Old 05-19-2010, 08:35 AM
Well you know everything so maybe I was mistaken lmao
Old 05-19-2010, 08:47 AM
Idk, I just assumed they kept the same 4x100 bolt pattern for all the 4-lug hubs. Then again, the accord has a freaking retarded front brake setup, so I wouldn't put it past Honda to have thrown a different bolt pattern on the hub, too.
If I'm not mistaken, a '94 Si should have the larger front brakes with ABS. I don't know how that would play out as far as the wheel fitment goes. There's always the possibility of small wheel spacers to give the wheels a little extra clearance. Actually, I'm going to read up on it and find out some real info lol
*edit:
Okay, did some reading. There's mixed opinions; from what I can tell, the wheels will fit just fine on '94 SIs without ABS. If the car has ABS, you may have to grind down part of the caliper bracket just a hair or use 5mm wheel spacers to clear the calipers. Also, apparently ABS was an option on the EG SIs. Maybe I was just spoiled having a fully loaded Ej1 complete with factory 4-wheel disc brakes
Old 05-19-2010, 06:03 PM
TheJGB3's Avatar
1988-2005 Civics are 4on100MM
2006+ Civics are 5on114.3MM
1978-1987 Preludes are 4on100MM
1988-1996 Preludes are 4on114.3MM
1997-2001 Preludes are 5on114.3MM (the BB9 Preludes in Europe came with 4on114.3MM)
Accords are 4on114.3MM until ~2000 then went 5on114.3MM
Old 05-19-2010, 06:20 PM
1988-2005 Civics -- 4x100
2006+ Civics -- 5x114.3
1978-1987 Preludes -- 4x100
1988-1996 Preludes -- 4x114.3
1997-2001 Preludes -- 5x114.3
Accords -- 4x114.3
There made it readable, and I knew I was right! lol
Old 05-19-2010, 06:21 PM
Rich's Avatar
I kinda like these rims:
http://cgi.ebay.com/ebaymotors/15-Bl...mZ160434525558
What exactly does "Bolt Pattern - Universal 4x100 and 4x114.3" mean?
Quick Reply: What stock Honda wheels bolt right on to a '94 HB Si?
