wheel bearings
Old 03-20-2007, 05:58 PM
rickyboy's Avatar
Default wheel bearings
Hi everyone,
Anybody know what's involved in changing wheel bearings on a 1996 Honda Civic.
Thanks in advance.
Rick
Old 03-20-2007, 08:02 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: wheel bearings
Well, I changed mine (93 civic) a month ago. You have to remove the wheel, obviously, the calipers, rotors, and finally the assembly the bearing is in. Once the assembly is off, you "need" a press to get the bearing out. Then, you NEED a press to get the new bearing in. It was easy popping out the old brken bearing but getting the new one in sucked. Wait, it might have been the other way around, I forgot. But either way, I needed a press to get the bearing in or out, so you'll need one regardless. Put a little lube on the new bearing to help it in place. Good luck!
Old 03-26-2007, 11:07 AM
If you will change rear ones, job is really easy, just remove the wheel, then remove the brake drum, using a fine point screw driver and a hammer remove the bolt cover, then just remove the bolt with a 1 1/4 wrench and you're done. Just replace wheel bearing assembly with a new one ($50 + or -) and you're done.
thakid
12-14-2011 01:48 PM
mars317
04-09-2008 05:10 PM
02blackex
08-01-2007 09:49 AM
POIZN
06-13-2006 06:55 PM
vdog
11-21-2005 12:20 PM
Quick Reply: wheel bearings
