Will The strut Bar fit?
RE: Will The Sway Bar fit?
I think you mean to say STRUT bar. The sway bar is located under the engine, still, not to be confused with a tie bar. I've heard there are some that fit, but there are only certain ones that do.
the ONLY bars compatible with the aem intakes is the neuspeed bar that hugs the chassis or the dc sport ones
if you plan on a swap later on, get the neuspeed. if you don't get the dc sport one. cost wise, both are about the same
dc has 2: the cs-2 is newer and more expensive and comes in only one color: same as the v2. hope that helps
