Window Issues
Old 04-09-2008, 11:37 AM
joespaghettio621's Avatar
Default Window Issues
I keep hearing about how automatic windows arent very good except for the fact you can roll them up/down with a push of a button. I have a 2000 Civic EX 2 dr. I noticed that after I roll the windows all the way up (passenger and driver sides) that i can still move the window forward and back.....even more so on the drivers side. And when I roll them up and down it seems to me that the front track on both sides moves out and in. Is this normal or should I replace the tracks?
Old 04-09-2008, 06:19 PM
KarTuneMan's Avatar
Default RE: Window Issues
Some movement is normal. Pull the door panal and look the rubber over down inside the door. The glass itself is a breeze to remove. 2 10mm bolts, and lift the glass out carefully. Both the front and back of the window guides can be manipulated a bit, so you can snug it up a bit..... but not too tight. Remember, some movement is very normal.
Old 04-09-2008, 07:04 PM
Yea, Ive had both door panels off for a while. I had to change the lift motor on the passenger side. When I bought the car,thedrivers side window was off the track and it looked to me like someone had broken into the car before through that window. I havent taken the drivers side window out but as soon as it clears up here for a few hours I will. I just dont want the window too loose. Ive only had the car for about a month now and someone has already broken into it by slipping the drivers side window out of the track.
Old 04-09-2008, 09:27 PM
Jeremy102579's Avatar
that gen civic is known for windows sucking.
my 2000 ex coupe drivers window sometimes come off track, i have gotten the regulator replaced.......but i still hate to use the window.....i normally drive with my windows up anyways.
i hate to use the window and have it come off track.
David Cooley
06-10-2012 12:11 PM
gospeed
09-25-2010 04:59 PM
teamwhiplash09
02-08-2009 05:32 AM
pltnim
06-20-2008 10:17 AM
joespaghettio621
03-18-2008 05:01 PM
Quick Reply: Window Issues
