B16A2 horsepower
Old 04-30-2010, 06:32 PM
98 EX Runner's Avatar
Default B16A2 horsepower
Hello, I am new to this forum and I have a 1998 honda civic ex. I plan on swapping my d16y8 with a b16a2. I am looking to get around 200 horses out of my b16. What is the easiest way to get 200+ horses out this engine without adding a turbo and without spending a ton of cash.
Old 04-30-2010, 06:38 PM
not gonna happen, to get to 200 hp your gonna need around 60-70 more hp. it costs $$$$$$$ and the only way i see it is turbo.
why a b16, it puts out about the same power you have now, i say get a b18c1 thats where the powers at.
Old 04-30-2010, 06:43 PM
Well the b16a2 is a lot cheaper than the b18c1 and from what i understand its a whole lot easier to swap.
Old 04-30-2010, 07:03 PM
alot easier....????? they are the exact same bolt up patteren, they have the exact same casing.. dont listen to who ever is giving you these ideas.
the b18c1 is a little more than the b16, but for the hp it comes with, it almost comes with 200hp. the cost to get the b16 which is a 1.6L the same as your d16y8 to the 200 hp mark will be far more $$$
Old 04-30-2010, 07:18 PM
So the b18c1 swap is basically the same as the the b16 swap? Are there any clearance problems or fabrication issues that I will run into?
Old 04-30-2010, 07:31 PM
they are exactly the same swap
Old 04-30-2010, 07:39 PM
Wow!!! Hey thanks a lot for the input man. It does make a lot of since now that I think about it. With the b18, I can do a couple of bolt on mods and be pretty close to 200 hps. Any suggestions on the best website to order the engine from? Hmotors is the best from the research ive done so far.
Old 04-30-2010, 07:48 PM
hmotors is a good a real good place
Old 04-30-2010, 07:55 PM
Very good. Hey thnx again for the info.
Old 04-30-2010, 08:01 PM
B16A2
Found in:
    • 1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
    • 1992-1997 Honda Civic Del Sol EDM VTi (EG)
    • 1996-1997 Honda Civic Del Sol USDM "VTEC"
    • 1999-2000 Honda Civic USDM Si (EM1)
    • 1999-2000 Honda Civic CAN SiR (EM1)
    • Displacement: 1,595 cc (97.3 cu in)
      • Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
      • Compression: 10.2:1
      • Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
      • Transmission: Y21 or S4C
      • Redline...8000 rpm
      • Rev Limit...8450 rpm
      • VTEC Engagement...5,500 rpm
      • aluminium casting
B18C1
  • VTEC
  • Found in:
    • 1994-2001 USDM Integra GS-R (DC2/DB8)
      • Displacement: 1,797 cc (109.7 cu in)
      • Compression: 10.0:1
      • Bore: 81 mm (3.2 in)
      • Stroke: 87.2 mm (3.4 in)
      • Rod Length: 137.9 mm (5.4 in)
      • Rod/Stroke Ratio: 1.58
      • Power: 180 hp (127 kW) @ 7600 rpm
      • Torque: 128 lb·ft (174 N·m) @ 6200 rpm
      • Redline: 8100 rpm (Fuel cut-off @ 8200 rpm)
      • VTEC Engagement @ 4400 rpm
      • Transmission: Y80(No LSD) 5-Speed Manual Transaxle
Quick Reply: B16A2 horsepower
