1989 civic dx hatch build
Old 09-23-2013, 04:55 AM
thatguywithahonda's Avatar
looking for fair priced brakes for disc in the front like big brakes or ebc something like that, since the oem onces are rusted and need to be replaced.. Just want a little more stopping power. The rear i want to know what is needed to do a rear bdisc conversion since i have open rims and it just looks nasty old rust drum brakes.
  #102
Old 09-24-2013, 07:03 AM
zerojett's Avatar
rear disk brakes have been beaten to death. there are multiple DIY/"How To"s on disk brakes for the EF hatch.
For the front brakes, there are OEM options. You can upgrade the stock DX knuckle to 10.3" rotors or full 11" rotors if you want. The Easiest Brake Upgrade. Shaved t23/t25 caliper bracket and 17cl13vn calipers, 88-95 sedan EX rotors.
  #103
Old 09-24-2013, 04:53 PM
Turtlegrip's Avatar
  #104
Old 09-26-2013, 06:03 AM
im trying to get upgraded brakes for example like these rotor's with these pads.
Something along these lines. Just need extreme breaking for when i take it for autocross.
EBC GD403 3GD Sport Brake Disc | Auto Parts Warehouse
http://www.procivic.com/pages-produc...Fc6e4AodVisAhQ
Almost ready to put the engine will be posting photos soon. What car do i need a master slave cylinder off if i have an s4c transmission and a crv motor?
  #105
Old 10-02-2013, 05:24 PM
Turtlegrip's Avatar
Cant help you there as I have stuck with OEM rotors and pads always. I would suggest just getting blank rotors but its arguable. High temp brake pads that wont glaze is something youll want.
I would get whatever clutch (im guessing you are talking about clutch) cylinders from whatever car the s4c is off of. If you are worried about lines fitting this might be a good time to get a soft tuckable clutch line, rywire has some good (expensive) stuff...
  #106
Old 10-28-2013, 05:19 AM
Thanks for the break advice. Just picked up a TD04 off a subaru forester from my buddy for $85. Any advice on boosting regarding the set up and what i would need custom made. Will probably be running between 8-12psi and pictures are coming just got the engine out of my car.
  #107
Old 10-28-2013, 09:33 AM
custom make everything
  #108
Old 10-28-2013, 09:47 AM
can you mention specific things? I am wet sleeving the engine anyone mention how it helps the process of instillation and possible cost
  #109
Old 04-22-2014, 07:09 AM
Just picked up a t3/t4 hybrid turbo. Anyone know good e85/ furl set up? Just to check how do I know if my cars mfi? The old motor on the top said pgmfi
89civicdxhatch
01-12-2007 03:47 PM
WHISP63
10-20-2006 09:08 AM
zil
12-08-2005 10:42 PM
mycivic
11-30-2005 04:25 PM
speedstream
08-12-2005 08:31 AM
Quick Reply: 1989 civic dx hatch build
