Garage Mod Lists Errors
A couple minor errors I've noticed that are a little annoying, and I figured they would be worth fixing if it's only a couple clicks of the mouse for an admin to fix it. Otherwise don't worry about it.
Anyway, the ampersand (&) and regular quote marks (") do not work in the Garage modifications list. When you type an ampersand it changes it to the HTML ID for the ampersand, which is like "&". This is a little annoying considering I have H&R Springs, and H and R just looks funny. Not a big deal, but if this is an easy fix then go for it.
Regular vertical quote marks do not work either, however the slanted ones do.
Also, I cannot post a hyperlink using BB code for some reason in the garage.
