HCF Suggestion / Forum Help Center This section is for suggestions and help pertaining to the forum, not for help with a car.
How post clickable words that redirect to websites?
Old 01-31-2009, 08:40 AM
Default How post clickable words that redirect to websites?
In caveman fashion, I post entire weblinks into threads. It's time for me to modernize. Can some wise person please tell me how to do what the title states?
An example of what I would like to learn to do can be found in post #2 of this thread:
https://www.hondacivicforum.com/foru...ad.php?t=72724
Old 01-31-2009, 09:42 AM
[url=http://example.com]Example[/ur]
replace " http://example.com" with the link and replace "Example" with the name. also add an "L" to the word url at the end. can't post the whole code or you would see what you want to see instead of the code.
i've just searched up wikipedia and this should help you. the codes under BB Code would work on forums. the code you want is the 6th code. hope this helps
http://en.wikipedia.org/wiki/Bb_code
Old 01-31-2009, 09:53 AM
mudferret's Avatar
You can also use the icon that looks like a world, with a single chain link beneath it when you're posting, or replying. Highlight the word that you want to act as the link, and then paste the url in the box that pops up. Does the same as the [ url= ......]example[/url]
Old 01-31-2009, 10:02 AM
mudferret's Avatar
You can also do the same in your sig.
Old 01-31-2009, 10:20 AM
Thanks for the response. I tried your suggestion several times but couldn't get it to work. I likely did something wrong. Is it possible that method doesn't accept a name composed of two words separated by a space (e.g., The Example)?
Old 01-31-2009, 10:22 AM
Thanks. This method worked for me right off the bat, as evidenced by my "new" cleaner signature.
Old 01-31-2009, 11:46 AM
i've use my code several times and it works for me. but glad that the other suggestion worked out for you. btw. your sig looks a lot cleaner
Old 01-31-2009, 11:59 AM
Thanks again. I probably made some type of syntax error, though I retyped the phrase several times.
Old 01-31-2009, 12:02 PM
I see that you already got your question answered, but here's the easiest/fastest way to do it.
1. Type your words (they can be any number of letters, numbers, spaces, etc.)
2. Highlight the word or phrase you want to be the link and then click the hyperlink button.
3. Type or paste the URL of the web page you want to link to, and click OK.
4. End Result:
Old 01-31-2009, 12:08 PM
Thanks everyone. Trust, nifty instructions. Hopefully, other members will also benefit from this information. Or possibly I'm the only member who didn't know how to do this.
StifflersMom
11-08-2006 10:30 AM
MichiganRice22
06-30-2006 04:27 PM
Remmy
09-29-2005 08:30 PM
Quick Reply: How post clickable words that redirect to websites?
