best intake manifold?
Ooo.. TB size is a tough one. With your power goals, I would suggest something 65mm or bigger. I would suggest to pick up the intake manifold you want first, measure the TB opening and determine that to be the smallest size TB you should run. If you want to run any bigger, bust out the dremel and bore out the intake manifold TB opening. Make sure you do this while the manifold is off the car since you have to flush the IM out with water and let dry. This prevents any shavings from entering your motor.
strtballer98
05-20-2007 08:39 PM
