01 ex shifting problem
Old 01-21-2015, 07:27 PM
01honcivic's Avatar
Default 01 ex shifting problem
the will start and idle fine,
*auto trans*
but itll rev up if I don't ease onto the throttle very slowly, like it goes into neutral.
if I ease onto it, itll be fine drive.. whats the problem?
speed sensor?
Old 01-22-2015, 05:33 AM
Manual or automatic? If it's manual, this sounds like the clutch is worn out. A bad clutch will "break away" and let the engine rev up without the car going faster if you give it too much gas.
Old 01-22-2015, 05:35 AM
01honcivic's Avatar
Automatic. Sorry I forgot to put that in
Old 01-22-2015, 05:01 PM
itburnswhenIP's Avatar
the problem is 01 civics had faulty automatic transmissions they knew about it but never issued a recall the 03 05 got a upgraded internal filter but that was basically just a band-aid for the problem. i blame hondas reputation getting ahead of them also greed. but maybe you got lucky and just have bad solenoids. when is the last time you changed the trans fluid is the fluid at exact level ???
dsmoore
03-13-2018 08:25 AM
jvcivic
10-29-2008 07:49 AM
chikna
07-18-2008 10:51 AM
jvcivic
05-11-2007 07:54 PM
ic892003
07-21-2006 10:54 PM
Quick Reply: 01 ex shifting problem
