Valve adjustment
It's a relatively straightforward job. Remove the valve cover and upper timing belt cover. Turn the crank to TDC1, 2, 3, or 4 to adjust the intake and exhaust valves using a feeler gauge. If your 97 Civic has never had a valve job, then now is a good time to do it.
1997, 97, adjsutment, adjust, adjustment, adjustments, civic, cx, feeler, gauge, give, honda, job, valve, valves
