1992 Honda Civic EJ coupe D16Z6 stock
Old 11-02-2014, 11:46 PM
Louie@909's Avatar
Default 1992 Honda Civic EJ coupe D16Z6 stock
car won't start on cold days..check engine light stays on when key is switched on..No buzzing noise..No voltage from main relay to pump but I changed the main relay and new pump..getting voltage to ignition coil..all my fuses are good..on a hot day car runs fine..but next morning when cold car won't start..any ideas what it might be or what I can do to fix my 93 EJ...anyone :-)
Old 11-03-2014, 05:58 AM
Once you're sure the main relay is good-- even a new one I'd open up and resolder-- this problem is usually the ECU itself being faulty and slow to boot up. Look for a used ECU.
Old 11-03-2014, 10:00 AM
Louie@909's Avatar
Thanks.. I'll give the main relay a look at again
cowsgonemadd3
09-13-2007 04:28 PM
womenbeshoppin
12-28-2006 03:14 PM
theharlequin
EG Swaps
12-24-2005 09:13 PM
04srt4black
11-03-2005 12:30 PM
Picit
09-07-2005 09:41 PM
Quick Reply: 1992 Honda Civic EJ coupe D16Z6 stock
