1994 Honda Civic wont start
Old 10-01-2012, 03:35 PM
rainydaze's Avatar
Default 1994 Honda Civic wont start
I have a 1994 Honda Civic 1.6 vtec automatic....
It wont start! Here's what we have done already
1) pulled the starter and had it tested... it was good
2) pulled the battery and had it tested... it was good
After doing this and reinstalling starter and battery it started twice and now wont start again.
In the process of removing and reinstalling both we cleaned all connections and even replaced the battery connectors so they would tighten down good.
When the key is turned nothing happens except all dash lights come on.
What should we check next?
Old 10-01-2012, 03:52 PM
Put transmission in Park and set the brake. Leave key off. Go under the hood and unplug the small wire from the starter, then touch a test wire from its small terminal on the starter to + on the battery. The engine should crank (it won't actually start because the key is off). This shows the starter, battery, and large power and ground wires are OK.
If that test passes, you should investigate the interlock switch on the shift handle. It closes the circuit between the key and the small wire to the starter only while the shifter is at Park or Neutral.
David_S
10-24-2013 10:06 AM
Infinite Shadows
03-31-2012 04:14 AM
bmelloh
05-16-2009 08:01 PM
mylesrmt
02-22-2007 07:58 PM
thakid
12-18-2006 11:38 AM
Quick Reply: 1994 Honda Civic wont start
