1995 honda civic having problems
Old 06-24-2010, 07:39 PM
turbo6jc's Avatar
Default 1995 honda civic having problems
I just bought a 1995 honda civic and started having problems the the day after I bought it.
It won't rev above 3500 rpm's. It acts like I hit a rev limiter. I replaced the fuel filter and plugs. after that it ran good for about 10 minutes then started acting up again. The plugs are white. The engine light is not on. isthere any way to check codes if it is not on? Any suggestions or insight on this problem would be appreciated.
Old 06-24-2010, 08:09 PM
Make sure the CEL has not been disabled. It should come on for 2 seconds when you turn the key on but don't start.
Old 06-24-2010, 08:17 PM
Most of the time the CEL is disabled by removal of the CEL bulb. Check that first.
Old 06-25-2010, 06:27 PM
turbo6jc's Avatar
the CEL does not work. I will look into getting it fixed.
Old 06-25-2010, 07:33 PM
Use this guide to access the back of the gauge cluster to check for a missing bulb.
https://www.hondacivicforum.com/foru...ad.php?t=81019
am123
09-15-2012 01:52 PM
robman1256
09-06-2011 01:49 PM
turbo6jc
06-27-2010 07:09 PM
limerence
11-17-2007 10:59 AM
gotrice32
08-03-2007 01:20 PM
Quick Reply: 1995 honda civic having problems
