1995 honda civic having problems
Old 06-27-2010, 06:01 PM
turbo6jc's Avatar
Default 1995 honda civic having problems
I've been having problems with my 95 civic. I had it scanned and the said i need to replace the air intake temp sensor & the distributor. I did both and i still have the same problem. Do i need to reset the ecm?
Old 06-27-2010, 06:07 PM
Click the CEL link in my signature to learn how to pull CEL codes yourself. Post the codes you pull.
Old 06-27-2010, 06:13 PM
turbo6jc's Avatar
my cel does not work
Old 06-27-2010, 06:22 PM
turbo6jc's Avatar
how do i reset the ecm?
Old 06-27-2010, 06:50 PM
The previous owner may have disabled the CEL by removing the CEL bulb in the cluster. Check that first.
Old 06-27-2010, 07:09 PM
You need to reset the ECU after repairs or the codes will still be stored (though the CEL, if it worked, will go out after the problems are fixed). You really have to have a working CEL to know what is going on.
To reset the ECU, disconnect the battery ground lead (with the key OFF) for about a minute. Or pull the "BACK UP" fuse out of the underhood fuse box for a minute, again with the key off. Either procedure is going to reset the radio, there is no way to avoid that.
am123
09-15-2012 01:52 PM
robman1256
09-06-2011 01:49 PM
turbo6jc
06-25-2010 07:33 PM
limerence
11-17-2007 10:59 AM
gotrice32
08-03-2007 01:20 PM
Quick Reply: 1995 honda civic having problems
