1998 Civic Computer problem
Hi, I have a 98 civic dx with the 1.6L. Car has 200k miles and runs GREAT. However, recently the car will die with NO warning. The "Check Engine " light comes on and when I put an OBD scanner on the car it says "No Link". At this stage the car will crank but NOT start. If I remove the battery cable for about 3 minutes and then reattach it the car will start and run normally with NO check engine light. There's no pattern to when it dies.
Any suggestions?
Thanks, Scott in KC, Ks
Any suggestions?
Any suggestions?
Any suggestions?
So when the car dies and the CEL comes on, does it go away when you turn the key again (not starting the car). The CEL should come on for a few seconds and shut off signifying the fuel system is priming.
If you jiggle the key in any direction while the car is on, does it shut off? I had a buddy with a Prelude where his ignition switch or whatever was loose/broken and the car would shut off randomly if the key was moved. It took him forever to drive through a bumpy area. lol
chadtheman05
10-21-2011 08:03 AM
LucidSteel
08-01-2010 10:26 AM
addiction2bass
09-26-2009 10:10 PM
