1998 honda civic issue
Connections
Check the connections from the battery and make sure there is no corrosion on the wires. If there is use a wire brush clean up the connections to th battery and see if that works.
Since the lights do not come on its clear that there is an issue with the connections to the battery.
Yeah, good point jump start the starter and see if it clicks. Use a flat head screw driver and touch the postitive to the negative on the starter. I recommend using a screw driver that has a rubber handle or plastic handle lol.
mudhenFUF
01-16-2023 08:43 PM
musky
03-23-2015 05:40 AM
WKD_DRGN
09-12-2010 04:28 PM
MBrent
09-11-2009 01:35 PM
