1999 Honda Civic Stock Radio Removal - HondaCivicForum.com
Reply
Old 05-31-2008, 10:15 AM
Default 1999 Honda Civic Stock Radio Removal
My friend has this 99 civic and she cant get the stock radio out and ive tried and niether can I so does anyone know exactly how to take the thing out?!!?
Old 05-31-2008, 10:38 AM
Default RE: 1999 Honda Civic Stock Radio Removal
Old 05-31-2008, 01:20 PM
A couple of things you need to do.
1. Remove the glove box by pressing the sides until the glove box goes all the way down.
2. Remove the driver's underside trim by removing 3 screws. (2 on top and 1 on bottom or vice versa).
3. You need to pop it off, it is held in place by 2 or 3 places.
4. Now you will see one bolt on the passenger side and one screw on the driver side for the center dash trim. It also has 2 screws just above the aux cd player as well. Remove those 4 and you can remove the center dash trim. You will need to unplug the cigarette lighter if so equipped.
Now you can look up from the bottom and see those 2 bolts holding the radio in place. Once you remove them, it slides right out and you will then need to unplug it.
Know that by removing the stock radio, you also remove any possibility of using your keyless entry as they are connected to the stock radio.
I will post some pictures of what I am talking about in 1-4 above.
Old 05-31-2008, 01:25 PM
Old 06-01-2008, 09:43 PM
TheJGB3's Avatar
The keyless entry connected to the radio is onlyon 96-98 Civics. The 99+ Civics are NOT wired this way. The OP said he had a '99.
Old 06-02-2008, 03:22 AM
here is a good DIY on the install and removal of the radio
http://www.norcalcivic.org/forum/vie...?f=8&t=553
Old 06-02-2008, 07:42 AM
didn't realize that the change took place in '99. that's good to know for future reference.
Reply
Thread Thread Starter Forum Replies Last Post
1999 Honda Civic Radio melissa16ann Audio/Visual & Electronics 0 11-21-2011 08:45 AM
1999 civic door locks and front radio speakers not working fbbyrd Mechanical Problems & Technical Chat 9 08-12-2008 06:16 PM
96 stock civic stock radio.....no sound germancivic Audio/Visual & Electronics 4 02-04-2008 12:03 PM
WTB: OEM Honda Radio Harness 1999 C8Chris Private 'Wanted' Classifieds 9 08-21-2007 08:32 AM
Removal of stock radio? Jeremy102579 Audio/Visual & Electronics 5 03-21-2005 03:46 PM
Tags
1998, 1999, 2000, 99, civic, honda, instructions, lx, radio, removal, remove, removing, stereo, stock, trim
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
