2 rubber tranny fluid line leaking- have to drain fluid?
Old 06-14-2014, 12:04 PM
pippo's Avatar
Default 2 rubber tranny fluid line leaking- have to drain fluid?
Anyone know if one has to drain the fluid to change one of the tranny fluid cooling lines (title says 2 lines, but only one is leaking/bad)- the one closer to the passenger side (shorter one). Its oozing fluid, and its time to put in new.
Thanks, people.
Old 06-14-2014, 02:34 PM
I don't think you would, especially if you drive up on ramps or otherwise raise just the front of the car so that it is tilted back. Of course the fluid that is in the lines and the cooler is going to come out so you will need to top up.
Old 06-15-2014, 04:04 AM
pippo's Avatar
thanks, mk. Oh- those lines, where do they go? the radiator? I mean, a seperate rad compartment that cools the fluid?
Old 06-15-2014, 04:40 AM
Yes there is a separate compartment inside the radiator. The hot transmission fluid passes heat through the walls of that compartment to the relatively cool coolant in the bottom compartment of the radiator. The coolant in the bottom of the radiator is relatively cool as it is on its way back to the engine.
Old 06-16-2014, 12:08 PM
pippo's Avatar
Thanks, MK- I get it now......
addiction2bass
03-27-2010 07:03 AM
beagler
04-09-2009 05:39 AM
fab4beatlefan
03-31-2008 11:09 AM
windcalmer
12
09-03-2006 10:13 PM
hailcivic
05-02-2006 09:31 PM
Quick Reply: 2 rubber tranny fluid line leaking- have to drain fluid?
