2000 civic speedometer
Old 04-20-2012, 03:26 AM
mycam8u2's Avatar
Default 2000 civic speedometer
i was wondering what the problem is when my speedo bounces around and doesnt seem to be reading the correct speed. also how do i go about resetting the cel? thanx for any replies.
Old 04-20-2012, 03:17 PM
droopy128's Avatar
Check the CEL first before clearing it, other than that check the connection on you speed sensor which attached to the transmission
Old 04-20-2012, 04:12 PM
Check if the odometer always works properly. That helps to tell if it's the sensor or the speedometer / odometer head in the cluster. Like the other guy said, use an OBDII scanner and read the ECU codes to see if the speed sensor code is in there.
Old 04-22-2012, 12:23 PM
mycam8u2's Avatar
i changed the speed sensor but the speedo is off quite a bit. it reads faster than the car is actually going
Old 01-14-2013, 04:13 PM
g3532's Avatar
I own a 2000 Civic HX and have always noticed my speedometer reads 5 MPH faster than actual speed (I noticed it when passing the radar stations on certain highways; also checked it with handheld RADAR). Now, the speedometer is acting up as mentioned by other members...drops to zero and back to actual speed sporadically. Will start by checking connection at transmission since the C.E.L. has not activated.
Schimmel03
02-12-2007 09:36 AM
BRIAN05
01-22-2007 06:57 AM
mdawg
12-02-2006 01:44 PM
nigel_miguel
Canada, Over Seas & Elsewhere
11-28-2005 06:36 PM
Super Mario
05-31-2005 05:51 PM
Quick Reply: 2000 civic speedometer
