2000 EX, cranks but no start
Old 02-18-2017, 08:00 AM
Jeremy102579's Avatar
Default 2000 EX, cranks but no start
Hi all.
I have a 2000 ex coupe. Been in garage all winter hooked up to a battery tender. Went to start her today, she cranks but won't start. I hear the fuel pump working when i turn the ignition on. It was fine when i put her away back in November. Any ideas or suggestions ?
Thanks
Old 02-18-2017, 10:35 AM
Update:
We checked and its got spark, and also fuel after the filter.
Ideas ?
Old 03-09-2017, 04:32 PM
Duane4238's Avatar
I'd shoot some starter fluid into the throttle body. If it fires, you know the problem is in the fuel system. Just because you have fuel after the filter doesn't mean it's getting to the cylinders.
Duane
Old 03-11-2017, 10:38 AM
tenacity2986's Avatar
My car had the same issue, and it was a ground wire from the ECU. Some manufacturers mount a conductive ECU onto chassis, but Honda has plastic ECU cases. Make sure your grounds are connected because if the ECU says don't start, it doesn't matter what else you replace
Mecca8383
03-31-2014 05:15 AM
honvic
10-06-2013 01:50 AM
jerry814
26
02-14-2007 07:59 PM
Civicracer2910
07-11-2006 03:24 PM
black99ta
08-02-2005 05:24 AM
Quick Reply: 2000 EX, cranks but no start
