2000 EX Idling Too Low
Old 05-27-2010, 09:20 AM
the numbers will vary a bit motor to motor, but the general rule of thumb is that they should be within 10% of each other across the board.
120-120-117-119 is fine
120-90-120-119 obviously something is wrong
Old 06-01-2010, 11:16 PM
joespaghettio621's Avatar
I think I may have a hole in the muffler right under the front seats. Can that cause the CEL and a crappy idle?
Old 06-02-2010, 03:27 AM
if it's before the cat, yes
Old 06-03-2010, 04:22 PM
I went to Advanced and had them check the CEL codes and got all kinds of misfire codes. I told the guy what I've done so far and he recommended a crankshaft position sensor. Is this good advise and if so what kind of sensor do I have on my D16y8? 18mm diameter or 20??
Old 06-04-2010, 03:13 AM
Knowing which codes you're throwing would give us the best chance of helping you out.
Old 06-04-2010, 07:13 PM
So far thank you everyone for postin your thoughts. Yea I know I shouldve wrote down the codes before but I got em now. I went to a mechanic today who hooked up a Snap-on computer thing the my car and couldnt get any CEL codes to pop up after he cleared them. But before hand, like I said before, he did read all sorts of misfires, before clearing them. The CEL stayed off for a while but then came back on so I took it to autozone to have the codes read. Talk about running ****ty...almost like it was out of tune. Then upon coming home I couldnt get it to stay running w/o throttling it about 2500. The codes I got: P1399, P0300, P0304, P0303, P0302. A couple people said that I got bad gas and the injectors are clogged. Another guy said the cat converter is bad. I know nothing. PLease help.
Old 06-07-2010, 08:31 AM
Aeon_Blue's Avatar
Hey Joe...I've been having the same issues. I thought maybe it was my injectors that were dirty and bad gas as well but it's not. My FI have been cleaned and I've used Supreme Unleaded gas. But I still have the same issue you do. I would probably try to rule it out as your cat converter being clogged up.
Old 06-07-2010, 09:16 AM
Sounds like a bad coil or ICM inside the distributor, assuming the plugs, wires, cap, and rotor are fine. Could also be a clogged fuel filter or bad O2 sensor. For the latter, try unplugging it to see whether the problem goes away.
Old 06-10-2010, 01:01 PM
I still haven't figured my prob out. I am going to get a fuel pressure test done tomarrow. I did put some seafoam into the engine and gas tank. Seems to have helped it a little bit.
aztecaa
16
08-18-2013 09:26 AM
ltkenbo
12-19-2008 02:05 PM
justin
04-28-2008 09:05 PM
MD1032
07-17-2007 10:26 AM
icarus
11-21-2005 08:32 PM
Quick Reply: 2000 EX Idling Too Low
