2002 civic crank sensor problem help!!!!
Old 02-11-2013, 07:13 AM
honestabestransport's Avatar
Default 2002 civic crank sensor problem help!!!!
hi i have a 2002 honda civic ex coupe with 110k . i was driving it and the car suddenly die. i went to start it back up and it would start for a secod then bog out and die. from reading up i changed the crank sensor which did not help. but here is the problem, if i disconnect the crank sensor the car starts and runs fine other then it goes into limp mode meaning i cant go past a certain speed or rpms. as soon as i connect it, the car wont start. do you guys think the computer is shot? any suggestions?
Old 02-12-2013, 06:51 AM
dailydriver's Avatar
Have you scanned it yet? What codes do you get with the sensor connected? What about with it disconnected? Start the car in between tests.
Old 02-12-2013, 08:50 AM
no codes when pluged in, when its not plugged in its throwing the crank sensor codes when it was unplugged.
Old 02-12-2013, 09:39 AM
Check that the crank and cam are in time. It may be trying to tell you that the timing belt has skipped.
I didn't think it could run at all without a signal from the one at the bottom on the crank.
Old 02-13-2013, 07:59 AM
I say get a new camshaft sensor, water pump, serpentine belts and replace them. Reset top dead center using the instructions in your Haynes or Chiltons. If that does not work, then you probably have some sort of electrical issue that you should let a pro diagnose (at least I would, I hate wires)
denisholden
03-24-2013 05:15 AM
cjy01
11-07-2011 12:05 PM
zerojett
10-18-2011 03:01 PM
joshr799
03-22-2006 08:53 PM
ToddK
03-01-2006 06:28 PM
Quick Reply: 2002 civic crank sensor problem help!!!!
