2002 honda civic overheating
Old 08-19-2015, 10:39 AM
klawson's Avatar
Question 2002 honda civic overheating
I have a 2002 honda civic ex and it overheats while driving. It will not overheat while idling in the driveway or at a light etc....
Where can I start to troubleshoot this?
Also the fans don't kick on, I had to wire these to the battery directly with a toggle switch to turn off and on.
I don't know anything about cars, so any help would be great. Let me know if you need any other info!
Tried this to fix it already:
new thermostat
new radiator cap
all belts functioning properly
pressure test
all fluids are full and changed
cleaned out overflow resevoir
water pump is functional
Old 08-19-2015, 04:04 PM
itburnswhenIP's Avatar
i usually refer to this video
but from your checklist it sounds like it mite be a bad head gaskit ???
Old 08-20-2015, 10:03 AM
whitemtr2000's Avatar
Did you burp/bleed the system? Many times an air bubble becomes trapped in the AC system especially after the type of work you mentioned above has been done
ladybug
08-22-2010 08:04 PM
mike.stribling
07-13-2010 05:29 PM
jjcash0411
07-12-2010 02:24 PM
Kenneth Ames
03-20-2007 02:42 PM
trebor_2005
05-19-2006 01:40 AM
Quick Reply: 2002 honda civic overheating
