2005 Civic Ex Rough Idle at stops
I understand that there is a post on rough idles already so dont beat me up about this. Sorry. Here is my issue.
While at lights car starts to chug like its going to stall. It has never stalled and this does not happen every time at every light. For instance I drove it earlier and it did this, then I drove it again 20 minutes of it being parked and it did not do this.
Also, the rough idle will stop if I turn on the recirculation button and turn the circulation up in the car. I didnt try it with heat or air conditioning. It will go down to a normal idle if I turn on that button for some reason.
I last year had timing belt done, also several gaskets and an clogged pcv valvle that blew out a gasket as well. I had all the plugs done at that time too.
At times I will see water or condensation in the driveway after driving it. it evaporates and doesnt leave a mark in driveway.
Please ask me anything, I am hoping I can repair this myself as I just sunk a bunch in on fixing broken calipers, sway bars, etc and a few things that had the engine light on.
Any help would be great.
your link doesn't work but if i was you i would start by removing the IACV and clean it to see if that helps since thats free to DIY. DIY: forgotten tune-up mods - Honda Civic Forum also did they clean the second pcv by the oil filter ???
I think
When you turn on air or the air cond system ( Recirc ) the computer ups the idle a little to compensate for the clutch on the ac compressor. Some cars will also turn on the rad fan as a precaution.
If all the tune up stuff is good, possible you might be getting a weak cylinder, or possibly an induction leak.
Steve
Steve
Jeremy102579
15
06-28-2012 08:11 PM
Stumasters
01-20-2008 12:58 PM
plasticboob
05-19-2006 02:01 AM
