2005 civic fuel problems?
Old 04-10-2015, 06:28 PM
Uponblocks's Avatar
Default 2005 civic fuel problems?
Hey I have a 2005 Honda civic lx 1.7litre 2 door coupe and I am problems figuring out what is going on the car starts and runs fine but when I hit between 3000 and 4000 thousand rpm it craps out I have changed the plugs with no luck now I'm leaning toward fuel problem thinking the fuel filter just bought the car and haven't changed it since I have owned it does anyone know if I'm the right track or if there is another common problem that I am missing
Any help would be greatly appreciated also the engine light came on but did not give a code cleared the engine light and now it is back on
Old 04-12-2015, 06:16 AM
If the light is on there is a code. A common reason to refuse to go higher than 3000 rpm is that the timing belt has skipped a tooth.
Old 04-12-2015, 08:48 AM
Uponblocks's Avatar
Default 2005 Honda civic
Ok thanks for the tip I was wondering about the timing belt slipping a tooth I will try again to pull a code off the reader
Old 04-14-2015, 02:17 PM
itburnswhenIP's Avatar
how many miles/years are on your timing belt ???
WorshipKrista
08-26-2011 05:26 AM
kingmike678
08-12-2011 06:20 AM
loci
11-15-2009 04:59 PM
$RiCh$
03-12-2009 07:00 AM
colinwd18
08-12-2008 12:31 AM
Quick Reply: 2005 civic fuel problems?
