2005 Civic sporadic heat and runs hot
Old 03-08-2015, 02:12 PM
rcec89's Avatar
Default 2005 Civic sporadic heat and runs hot
My '05 Civic has had no heat at idle. When the engine is reved at 2k rpm the heat begins. This had been happening for a few weeks. Now the car is starting to run hot. Not overheating, but hot. Temp gage is between normal (middle ) and hot (H).
Changed the thermostat and drove the car for 20 minutes. No heat for about 10 minutes, then the temperature in the car got nice and warm. Shortly after, the temp gage crept toward overheating (H) and air turned cold. The gage never reached "H" and then slowly came down, but still hotter than normal. The lower radiator hose is not that hot. Antifreeze levels seem fine, no sign of leaks and engine oil seems clean with no water or coolant mixed in.
Anyone have any tips on what this is? Thanks
Old 03-08-2015, 05:30 PM
Is the radiator staying full? Don't just check the plastic bottle-- when the car is cold open up the radiator itself. A leaking head gasket will push coolant out of the engine and radiator into the bottle and it will not return. Heater not working though the engine is hot means there is a bubble of air in the system.
Old 03-10-2015, 12:53 PM
itburnswhenIP's Avatar
i post this constantly but ill post it again cuz its good info watch it ok. the issue your saying usually happenes when there is a air bubble trapped in your coolant system.
JBaris
05-05-2012 02:00 AM
jonsaidthat
07-22-2011 02:55 PM
Hagberg_P
07-08-2010 10:03 PM
Lensesi
19
07-31-2008 06:55 PM
justincg
06-13-2008 09:44 PM
Quick Reply: 2005 Civic sporadic heat and runs hot
