2005 honda civic ex key ignition reprogramming did not work
Old 11-24-2013, 08:58 AM
robertanesbit3rd's Avatar
Default 2005 honda civic ex key ignition reprogramming did not work
2005 honda civic ex, replaced ignition with used ignition. had new igntion key reprogrammed to car. reprogramming of key(s) says successful. green key light will not go off with reprogrammed key and car will not crank. hooked back up original ignition (that has been taken apart due to key locked in switch, cranking with screwdriver), car cranks. What has happened with key program process, is there a step that has been missed?
Old 11-25-2013, 05:48 PM
itburnswhenIP's Avatar
i would question the means in which the keys were programmed im guessing this wasn't done by a honda dealership ???
Old 11-26-2013, 06:49 AM
FIXED>>>
replaced the immobilizer control unit from old switch, put on replacement switch, reprogrammed keys. Is now cranking up and running
Was not done by Honda dealer. Local locksmith reprogrammed the keys. Honda dealer wanted way to much for same process. And I got a second key.
bwdrennan
02-08-2020 08:56 PM
civinoobie
12-29-2010 04:15 PM
ws6formula
12-24-2009 04:38 AM
shiaokaz
26
07-07-2008 06:44 PM
shiaokaz
05-09-2008 01:13 AM
Quick Reply: 2005 honda civic ex key ignition reprogramming did not work
