90 Civic Passenger Door / Belt Battery Drain
Old 08-04-2009, 04:30 PM
viejopatron's Avatar
Question 90 Civic Passenger Door / Belt Battery Drain
I've this battery drain located in the door/shoulder belt area. I was told the belt 'trolley' needed to be in the 'driving' position. I removed the trim on the B column and manually brought the trolley to that spot. I also disconnected the main connector in the B column. Still draining. I disconnected the door closed switch (black L lever).
After trying combos of the above, the battery still drains and in some case a persistent buzzer goes.
Any ideas? Anyone have a door/ belt schematic?
Old 08-05-2009, 10:57 PM
kdubbla's Avatar
Default hm
dude i have no idea what ur saying, but unhook your negative battery terminal, use your test light as a bridge between the terminal and the (-)post and the light should be very dim, if its very bright, have a buddy hold the light and you start yanking fuses 1by1 until the light goes out, then its pinpointed where the draw is.
Old 08-05-2009, 11:05 PM
have you had your battery tested...?
timmytim
10-03-2016 06:38 AM
abel333
06-23-2009 07:44 AM
tnicol01
01-29-2008 04:20 PM
baker7598
10-31-2006 03:06 PM
RLaP
11-17-2005 12:32 AM
Quick Reply: 90 Civic Passenger Door / Belt Battery Drain
