93 Civic drinking Oil
Old 06-24-2012, 08:10 AM
2012 Si's Avatar
You should not have steam/white vapor in your exhaust except during warm-up in cold weather. You have a problem with the head/gasket or other related area. The steam is from water getting into the cylinders.
I fixed a similar problem on an old Ford inline 6 (very differrent from a Honda,I know);the head was cracked in #3 cyl area.
Old 06-24-2012, 10:38 PM
dlcraig1's Avatar
Replaced PCV valve and hoses and cleaned out canister on back of block. It cut the oil consumption some. Switched to 10w-30 and it also helped but in the end after leakdown and compression tests both were good, I narrowed it down to frozen oil scraper rings on piston #3. Got bad enough that it burned the exhaust valves on that cylinder. So...new motor is in now.
David Murphy
08-22-2011 02:56 PM
henrythomas
11-01-2009 12:28 PM
oilltd
06-10-2008 04:06 PM
Crook_EG8
05-26-2006 11:54 AM
Quick Reply: 93 Civic drinking Oil
